OBD1 and OBD2 wiring harness
Question.. Which connectors are going to be different if any if taking a b18b from a 94 civic and putting it into a 96 civic. i am mainly concerned with the injector clips are they the same from OBD1 to OBD2? Thanks
Re: OBD1 and OBD2 wiring harness (KillerBee18)
No the injector clips are different. You would want to use the 96civic harness and the 96 civic injectors. I have a premade harness for that swap that will plug and play if interested. Click the link in my thread or Pm me. 90 bucks shipped and its yours.
The injector clips, distributor, alternator, IAT and possibly the IACV (depends on the model) will be different. As mentioned, you can reuse the OBD2 injectors for plug and play. You will need to rewire the IAT and IACV with the proper 2 prong round plugs. For the distributor and alternator you could use OBD2 parts for plug and play or just change the plugs and use the OBD1 parts.
