can someone do a complete write up of B16a1 into 1991 civic si??
im 17 and my dad wont let me do this swap unless we both know exactly what to do, and what will happen if i have someone else od it, we want ot know the pros and cons, and what to do, anything and everything will be useful...thanks
i have a 1991 civic Si, what do i need, and what should i get, and what should i do...thanks
Re: can someone do a complete write up of B16a1 into 1991 civic si?? (riceburners1)
so your dad would be willing to do the swap if you got a write-up from some anonymous person on the internet? you wont find anyone to do an exact write-up for you, and even if they did, you will run into problems regardless of how closely you follow the steps, and thats even assuming the directions are correct. doing a swap for the first time is no easy task and it's something that you have to approach knowing that there will be things you arent going to understand, and you will be very frustrated with. so prepare as best you can and tell your dad to have a little faith.
Re: can someone do a complete write up of B16a1 into 1991 civic si?? (quarterkorean)
Buy a Helm
Read How to Remove Engine
Read How to Install Engine
Then Wire up VTEC
Do a search there are a ton of post on What you need and how to wire up the VTEC...
Then Wire up VTEC
https://honda-tech.com/zerothread?id=637661
go thru this link. lots of info.
the swap is very easy once you have done it. when you are going to laugh at how easy it was.
