Distributor & EGR wiring. Plz Help
Former Sponsor
When I did my H22 swap last summer into a F23, I found a diagram chart showing what wires from the wireharness is connected with the distributor. However, I had to replace it, and I got the wires mixed up. I've been looking, but I can't find any information. Could someone please help me out.
Also, what three wires of the six are used to connect the EGR?
Thanks for all the help.
Re: Distributor & EGR wiring. Plz Help (-Bionic-)
sorry
i do not know what you are asking for
i wrote the EGR write up in the thread maybe i can help you
Former Sponsor
Re: Distributor & EGR wiring. Plz Help (turbogixxer)
Thanks for the time bro. Well I got a H22 swapped into my 6th gen accord. I'm using the stock harness, and I'm wondering what wires (color coded) that I'm supposed to use with the egr plug. The OBD II harness uses 6 wires for the EGR, while the OBD I uses three. Do you know which wires are used?
Thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">The OBD II harness uses 6 wires for the EGR, while the OBD I uses three. Do you know which wires are used?</TD></TR></TABLE>
not for obd two
will get the diagram tommorrow
not for obd two
Former Sponsor
Cool I appreciate it. Let me ask you you mentioned in an earlier post that:
ECU trigger - WHT/BLK - goes to D12
Sensor ground - GRN/WHT - goes to D22
Sensor voltage - RED/WHT - goes to D19 or A25
So basically. All I need to do is to use my manual to see which of the six wires are ground, voltage and "ECU trigger." Is that what it's labeled in the manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">Cool I appreciate it. Let me ask you you mentioned in an earlier post that:
Thanks for the help. </TD></TR></TABLE>
yeah
but the sensor may not work on just three wires
you catching me?
yeah
you catching me?
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
yeah
you catching me?</TD></TR></TABLE>
I only got three wires. white/black, green/blue and yellow/blue on the H22 EGR
The F23 EGR uses six wires.
yeah
BlazeInEk
05-03-2007 07:29 AM
BlackEG6
10-03-2006 10:09 AM
