Kseries into a 1996-1998 EK
I was wondering if there is anyone out there that post on here that might have this swap up and runnning.
I'm thinking of using the HASPORT kit and I'm going to pick up the RSX type S change over kit tomorrow. What all is needed from the RSX other that the usual motor/tranny/ecu/linkage????
Re: Kseries into a 1996-1998 EK (fullblownracing)
Robby, if you use anything other than the Hasport kit, you'd be nuts. I've got a small list of required items, and the easy to remember things are:
Hasport mounts (duh)
Hasport axles
Hasport wiring conversion
Hasport reflashed ecu or Hondata K-Pro
K20A motor/trans/ecu (for core), shift cable assembly with shifter from RSX.
Aftermarket Fuel Pressure Regulator (SX or similiar)
Radiator (custom would be best, and I bet you know someone who can do that)
Custom header, I hear Hasport just put one into production, but it is not yet available.
Thats the quick list.. If you've got any questions, you know my number..
-joe
Hasport axles
-joe
joe...your the man. anyways...you know I've been talking about it and it time to pull the trigger!! I'm picking up the swap today and I'm sure you'll be hearing from me sometime this afternoon!! HASPORT all the way baby!
Anyways...I was talking to S. Hiller yesterday and he was telling me about some things under the dash that I need to get. Is there anything else you can think of other that the obious?? The only thing I'm scared of is that if I don't get all of the parts today while I'm getting the swap the car could be gone. And with my luck if I need something once I start on the swap I won't be able to find a RSX to rape parts off of!! YOu feel me?
