vtec = no power
Old Mar 30, 2004 | 07:20 PM
ensracer's Avatar
Default vtec = no power
long story short vtec engages but there is no power gain i have swapped out speed sensor, distributor, ecu, vtec solenoid, checked motor oil pressure, checked head oil pressure when vtec engages, checked timing, ran solenoid to a switch and it is all ok. when i lean into it in second you car hear a very light noise around 5000 rpm's but there is no power gain. i had an h23 vtec that blew up and that thing kicked super hard and now i put in an h22a4 block with type s pistons with the same h22a head and i got nothing. not even the slightest bit of power. vtec is working but there is just absolutely no power at all it runs like an non vtec with good compression. this thing absoultely dies at around 6800 rpm's
wait i guess it is a long story....sorry
Old Mar 30, 2004 | 08:18 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default Re: vtec = no power (eduardo)
you check oil pressure?
Old Mar 30, 2004 | 08:26 PM
ensracer's Avatar
Default Re: vtec = no power (Jumpmann23)
yes oil pressure is fine
jumpmann23's Avatar
maybe you have just gotten used to all that h series power
Old Mar 30, 2004 | 08:57 PM
ensracer's Avatar
i dont think so... it is really not working
Old Mar 30, 2004 | 09:07 PM
jumpmann23's Avatar
are you throwing any codes
Old Mar 30, 2004 | 09:34 PM
ensracer's Avatar
yea distrubutor but i swapped that out also and still the same
Old Mar 30, 2004 | 11:13 PM
shocker's Avatar
What about timing is that all fine??? Also did you check to see if your vtec lobes are worn down for some strange reason
Old Mar 31, 2004 | 05:17 AM
Adam.'s Avatar
Put it on a dyno to confirm that you aren't making the hp you should be. Also, do a compression and leak down test.
ensracer
Apr 1, 2004 01:28 PM
ensracer
Mar 30, 2004 08:51 PM
ensracer
Mar 29, 2004 08:30 PM
