please help the noob
Old Apr 7, 2004 | 10:32 AM
b18bme's Avatar
Default please help the noob
I am not real smart when it comes to engine swapping but I did try and search but am still really confused. I am going to be putting in a b18b 99 motor in my 93 dx hatch. The 99 motor is obd2 and I need it to be obd1. Do I just need the wiring harnes converter or can I use like a 95 ecu or both. I plan on using hondata later when I get my turbo and I did find that obd1 is better for hondata. What year of ecu should I use for the swap. Can I use all other parts from the 99 or do I need to mix and match it with obd1 parts. Sorry but I need help quick? I guess what I am trying to say is how do I put the 99 motor in and have it be obd1 for hondata and to make it work in my car sorry so long?
Thanks in advance?
Old Apr 7, 2004 | 10:43 AM
SoulSurfer's Avatar
Default Re: please help the noob (b18bme)
You will need an OBD2 to OBD1 conversion harness. I got mine from Blown90Hatch. Great customer support.
You will also need an OBD1 ECU. I went with the P75 since it's the OBD1 LS ECU. I know a lot of people also used chipped P28s.
You might need to rewire the injectors and change the distributor to OBD1 but I could be wrong. I've heard so may different things.
Truedeal
Engine Management and Tuning
Dec 4, 2017 07:09 AM
brad98_teg
Dec 8, 2005 04:25 PM
b18bme
Apr 7, 2004 05:43 PM
Chiiip
Feb 27, 2004 08:00 PM
yupuhhuh
Feb 19, 2004 04:28 AM
