H22 into EG w/ integra axles
How good are integra axles for an h22 swap I know theyre not the greatest but will they do for a couple months? I'm gonna be going on vacation for 2-3 weeks then i'm gonna need to save up a bit to buy either dss or hasport axles but for the mean time are the teggy axles gonna hold up (cuz I need to finish the swap b4 i leave for vacation). Car is not dropped and will be riding on stock suspension plus front strut and rear sway bar.
Re: H22 into EG w/ integra axles (LudeSH)
I used 90-93 teg axles with accord intermediate shaft....and it binded when I turn left and hit bumps, it got really annoying. Then i heard that if you use an 89 teg axle it would make it stop, I tried it still binded. I had h&r sport springs with tokico shocks...
Re: H22 into EG w/ integra axles (JdmCIVIC853)
You have to hybrid them to make it run normal. I'm about to use an 89 Integra axle with prelude inner joint on the right side. My problem is I dunno how to switch out the inner joints . hehe. But with stock height, I would go for the 89 Integra axle on the Right side, accord halfshaft with 93 integra on the left and you should be fine. Be careful of leaking tranny fluid... use axle seals. I believe if you keep the prelude halfshaft, u can use 94+ GSR axle on the left side.
TH22A1
06-26-2009 08:28 AM
