swap into my ef help..............
i'm going to be swaping in a 1st gen b16a into my ef and had a question. i know that my ef is an si with a obd 0 type harness. is there any way to convert it to obd1? or can i only use obd0? thanks for the help................
Re: (MatHadder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatHadder »</TD></TR><TR><TD CLASS="quote">wow. 538 posts and still doesnt know how to search.</TD></TR></TABLE>
lol!!!!!!!!
Well in order to go obd-1 in your car you would need to either get an obd-1 engine and dash harness plus ECU,distributor, and injectors.
or
you can try to find a jumper harness that goes obd-0 to obd-1 to plug into your obd-1 ECU
IMO, these are the two easiest ways to do it. other than that you will have a wiring mess on your hands. what determines if a car is obd-0,1, or 2 is the distributor, injectors, and ECU.
Any honda/acura harness will work on any year from 88-00 its just that you would have different plugs for the dist., injec., and ECU.
STAY OBD-0!!!!!!!!!!!! it doesnt matter.........
lol!!!!!!!!
or
