Where do i add trans fluid to??????
Old 04-07-2004, 05:58 PM
Myh4tch's Avatar
Default Where do i add trans fluid to??????
Hey guys I have a 94 h22a jdm spec motor, i have no idea where to add trans fluid and i would really like some help as to where to add it....
If anyone could help me out it would be greatly apreciated... Thanks a lot!
Old 04-07-2004, 07:59 PM
AzNpRiD3's Avatar
Default Re: Where do i add trans fluid to?????? (1cleanEG)
there is a nut on the pasenger side. you take off the time and it is a little above the axle...dont have a pic but i think it is a 17mm.
Old 04-07-2004, 08:34 PM
Ryan C's Avatar
Default Re: Where do i add trans fluid to?????? (AzNpRiD3)
the easiest way to do it is via the VSS sensor.
just take off the 'real' fill plug and add fluid into the VSS hole until it comes out of the fill plug
Old 04-08-2004, 08:41 AM
C M S's Avatar
There is a long "tube" that comes out near the shifter arm. Remove the breather cap and fill!
Old 04-08-2004, 09:01 PM
Turbogixxer's Avatar
Default Re: Where do i add trans fluid to?????? (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">the easiest way to do it is via the VSS sensor.
just take off the 'real' fill plug and add fluid into the VSS hole until it comes out of the fill plug </TD></TR></TABLE>
best way
Old 04-09-2004, 10:45 AM
DXR
DXR's Avatar
Default Re: Where do i add trans fluid to?????? (turbogixxer)
VSS sensor? Pics? location? vividness please!
Old 04-09-2004, 10:51 AM
Default Re: Where do i add trans fluid to?????? (DXR)
https://honda-tech.com/zerothread?id=382416
ABlais
06-18-2008 06:52 AM
luv2boost
08-08-2007 10:06 PM
ajwiant
03-04-2006 08:33 PM
EG_Civic_Si
02-04-2006 12:42 PM
Myh4tch
04-08-2004 02:47 AM
Quick Reply: Where do i add trans fluid to??????
