OBD2 B18C1 into 94 hatch. code 41
is the primary oxygen heater wiring differnt in an OBD2 engine and an OBD1 chasis harness?
i replced the o2 sensor.. and i still get the error and i know the new one works.
i have noticed the two black wires..... on the engine side it looks like one of them has a white line on it. could it be wired differently?
i'm running an obd1 p72 and evap/iab/vtec/knock are all wired correctly and functioning.
yes i searched.. from searching i found out that the heater is just to heat the sensor up so it functions ebfore really warming up... so shouldnt the stupid code just go away. grr.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazynok »</TD></TR><TR><TD CLASS="quote">si (4wire.. so it should be the same i would hope..)</TD></TR></TABLE>
Yes both the GSR and Si use a 4 wire O2. Even in the OBD2 harness, the O2 wiring is the same so it will be plug and play on a 4 wire O2 chassis. If you've replaced the sensor and reset the ECU but it still gives the you a CEL, it's gotta be a wiring problem somewhere.
edwinie26
67
Jun 19, 2014 04:50 PM
lazynok
Mar 30, 2005 08:05 AM
ProjectXaccord
Nov 25, 2003 04:56 PM
