hot tank?
Old Apr 1, 2005 | 04:41 PM
JDM978's Avatar
Default hot tank?
yeah i can hot tank my bottom block rite? i know i can but this shop wer i mite go 2 get my engine rebuild say i cant do it & my block will melt
Old Apr 1, 2005 | 10:01 PM
miller.91.HB's Avatar
Default Re: hot tank? (JDM978)
You can hot tank your block but you must strip it bare... which kinda sucks. You'll end up having to buy all new seals.
Old Apr 2, 2005 | 07:54 AM
NJIN BUILDR's Avatar
Some shops only have cleaning equipment (solution) to do cast iron.The cleaner that they use will turn aluminum black.Most of the newer solvents will work on aluminum and iron.
Glenn
Old Apr 2, 2005 | 08:10 AM
dohcdelsol93's Avatar
Default Re: hot tank? (NJIN BUILDR)
I just had my engine re-worked and it was hot tanked. Lucky me, it didn't melt
Old Apr 2, 2005 | 02:28 PM
Hapexamendios EJ8's Avatar
Default Re: hot tank? (dohcdelsol93)
the term hot tank is just a generic term, actual "hot tanking" melts aluminum like mentioned above
Old Apr 2, 2005 | 05:42 PM
ernald711's Avatar
hot tanking is an excellent procedure and highly recommended with a rebuild... don't go to that stupid mechanic anymore...
Old Apr 6, 2005 | 04:03 PM
JDM978's Avatar
true i found anotha shop tat will do it bump for me
Old Apr 7, 2005 | 03:42 AM
THEUSED's Avatar
They Cold Tank Aluminum, mines at the shop right now, Im picking it up tomorrow
Old Apr 8, 2005 | 11:00 PM
redlineintegra's Avatar
Default Re: (THEUSED)
My machinist called it jet-washing .. hot-tanking uses acids that would eat away at aluminum.
Mr si99
29
Jun 16, 2005 12:30 AM
sporkcrx
Sep 27, 2003 01:43 PM
Smoothy
Aug 25, 2003 03:29 PM
mskibbz-T
Aug 18, 2002 07:57 PM
