B18a w/ 100k on it?
B18a w/ 100k on it?
Hows it goin fellas?Had a couple of questions about a motor I was about to get swapped in my Civic.Its a '95 LS b18a w/ 105,000miles on it.I was wondering what I could do too freshen it up a bit.The guy said he would be replacing the timing belts, water pump, and front seals.I might be looking to boost it down the road,but for now I just want it too run good.So what else could I do maintenance wise?Thanks.
Re: B18a w/ 100k on it? (Skip01)
Tune up -spark plugs/wires/cap and rotor. You could also have the valves adjusted. These should keep the motor in good shape for boosting down the road...
in my opinion i would rip the whole thing apart and put in some new oem main and rod bearings. new gaskets all around. the water pump and belts too like u mentioned before. if you are patient i would put in some eagle rods and some FI pistons since you plan on boostin down the road. save you the trouble of doing that later.
Re: (iROCKtheSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC »</TD></TR><TR><TD CLASS="quote">in my opinion i would rip the whole thing apart and put in some new oem main and rod bearings. new gaskets all around. the water pump and belts too like u mentioned before. if you are patient i would put in some eagle rods and some FI pistons since you plan on boostin down the road. save you the trouble of doing that later. </TD></TR></TABLE>
Yeah I was gonna build the internals,just wanted to freshen it up until then.Thanks for the replies.peace.
Re: (RexQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexQ »</TD></TR><TR><TD CLASS="quote">dont forget the ARP head studs. and everything else everyone said. head lifting is no good.</TD></TR></TABLE>
Yeah thats what i heard..its not really the rods or pistons its the bolts that hold them together that fail.thanks for the info
