Sensors (TB, Intake Manifold, vtec solenoid) compatibility
For 94-01 Integra (and other's that apply) Are the following compatible between the non-vtec & vtec heads?
-Idle Air Control Vavle (IACV)
-Fast Idle Thermo Vavle
-Map sensor
-evap purge control solenoid valve
-TP sensor (My helms says it's not removable, but I've seen bare TBs)
What year and model cars are the following compatible with:
-vtec solenoid (spool vavle)
thank you.
-Map sensor
thank you.
Re: Sensors (TB, Intake Manifold, vtec solenoid) compatibility (Takumi Fujiwara)
- Idle Air Control Vavle (IACV) - YES
-Fast Idle Thermo Vavle - Not Sure
-Map sensor - YES
-evap purge control solenoid valve - YES
-TP sensor - YES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">TP sensor (My helms says it's not removable, but I've seen bare TBs)</TD></TR></TABLE>
The TPS sensor can be removed without much trouble. All you need to do is take a dremel and notch across the rivet bolt and then unscrew them with a flat head screwdriver.
-Map sensor - YES
-TP sensor - YES
92eg_b16
12-13-2007 12:26 PM
compatability, compatibility, compatible, control, fujiwara, h22, honda, intake, manifold, map, sensor, sensors, solenoid, valves, vtec
