obd1 b18b1 into 98 EK enigne harness question
i thought this swap was so common but nothing comes up in searches or the swap thread up top. i would like to know what i need to do with my ek engine harness to work with my ob1 b18b1. i already have the ecu conversion harness. i have the motor in the ek now and need info on plugging and splicing the engine harness. also would a motor fire-up if my crank angle sensor at the crank pulley isnt working ( i suspect that sensor is damaged).
Re: obd1 b18b1 into 98 EK enigne harness question (rocketfuelcerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocketfuelcerx »</TD></TR><TR><TD CLASS="quote">What obd1 ecu are you using, you need an obd1 ecu</TD></TR></TABLE>
p75
p75
pnoyboldstar
04-13-2007 09:13 AM
