quick question h22 eg swap
ok i did a search and im still a little unsure about h22 wiring? already looked at H22 FaQ!
i had a 95 CX with H22 and im putting it into my 92 VX. what exactly do i need to change or can i just plug it in at the shock towers? ive been told that the VX is prewired for VTEC but i cant find the wires? otherwise im gonna take the vtec wires from the cx that were added. the engine harness is already lengthened and everything just need to clear up some little things.
on the passenger shock tower there is 4 plugs on the chassis harness and 3 from my motor do i just leave one unpluged? on the driver side everything just pluged in but there is one wire running along the top of the fire wall that im unsure what its for i looked on the cx and it doesnt have it? what is? do i need it? what do i do with it?
any help is appreciated if my question is unclear just ask.
just want to know what i need to change(do) if anything...TIA
Re: quick question h22 eg swap (iiturboswapii)
anyone?
all i need to know if i have a cx/prelude harness on my h22 and a Vx chassis Harness what i need to do to make it work? or do u just plug and play?
the vx chassis harness in addition to the vtec also has a 5 wire o2 sensor, as well as egr system. if i was in your shoes i would probably modify the vx harness to fit the h22a.
If you have a (2 then your in luck cause the 92's had vtec wires in the chasis/ECU side of the harness. You will need to modify the stock VX harness to reach all the sensor but you wouldnt need to run any vtec wires inside the car. There is a big sticky @ the top of the forum page with all the info you need.
1dopesi
09-14-2007 07:25 PM
