sohc manifold to y8 manifold questions
Purge Cut Solenoid Valve: Don’t bother with the one from the Y8 fuel rail…sell it on ebay. Just run a vacuum line to the stock A6 solenoid that is mounted on the firewall.
can u tell me where on the firewall a cn find this and where do i get the vacuum line from
I'm also using a gsr tb not my stock tb and on top of the stock tb theres a vacuum that runs to the charcoal canister now on my gsr tb there is no where to put the vacuum that comes from the charcoal canister where do i put the vacuum
i'm using a b18c5 gsr tb can i use the rotor that on the tb or do i have to use the one off my d15b motor
where the purge cut solenoid valve was what goes there now i was looking at the pic and it say that the bashpot goes there what and where is that
now i'm using a gsr tb do i still have to bypass the coolant from th tb and the iacv or do i hook it up with this tb
THANK FOR AL THE HELP</U>
fireant
12-14-2008 03:56 PM
racingant
03-30-2005 08:42 AM
JCracer723
07-29-2003 10:06 AM
