Boy am I up a creek!
I just found out that my state has passed a law prohibiting me from doing an engine swap! Well, I found out a bit too late as the swap is already finished, and the law is almost 2 years old. What this means is, my obdII car cannot be tested with an obdI motor for emmissions, since the diagnostics won't communicate with my ecu. What can I do about this? Is there any possible way around this by altering the vehicle, short of putting old motor back in???!!! My emissions already expired, Lord, I hate this state!
in every state it is illegal to convert back to prior emissions standards on a road driven car, and then on to pof that many states have hteir own laws. if its originally equipped as an obd2 they will not usually be allowed to test with a sniffer, and jsut wnat to scan the ecu. i suggest shopping for a place you can buy your inspection from.
Re: Boy am I up a creek! (Subwarrior)
most places wont check the motor they just run the test and if they dont ask dont tell them just let them think that its the stock motor
Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk »</TD></TR><TR><TD CLASS="quote">Make friends with some backwoods mechanic.</TD></TR></TABLE>
hahaha
hahaha
Re: (BS 22)
i know somne states u can swap out the motor of the same yr or newer into the car. ig: if the car is a 96 u must have a 96 or newer engine with all the emission items in place such as evap and things.
usually, if you can swap over all the OBDII emissions equipment over to the OBDI motor, you can at least put your car back in the right OBD category. from then on, it's just a replacement motor. but the laws vary by state. you said it was illegal to do a swap at all, but i would check some more into that. talk to a reputable shop in your state and see what they have to say.
and best of luck man!!!
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">in every state it is illegal to convert back to prior emissions standards on a road driven car, and then on to pof that many states have hteir own laws. if its originally equipped as an obd2 they will not usually be allowed to test with a sniffer, and jsut wnat to scan the ecu. i suggest shopping for a place you can buy your inspection from.</TD></TR></TABLE>
I live in florida. I have a '93 motor in a '99 car. It is perfectly legal.
cool guy name
Re: (DarkKnight1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight1 »</TD></TR><TR><TD CLASS="quote">
I live in florida. I have a '93 motor in a '99 car. It is perfectly legal.</TD></TR></TABLE>
You 100 percent sure on that one?
cool guy name
Re: (jdm_Integra0369)
I'm not saying the likely hood of anyone checking. I'm saying in the LAW does it say that its allowed? I live in VA and its the same way, no one will ever know or check but in the Law its not allowed.
Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">I'm not saying the likely hood of anyone checking. I'm saying in the LAW does it say that its allowed? I live in VA and its the same way, no one will ever know or check but in the Law its not allowed.</TD></TR></TABLE>
No, there is no law that says it is allowed.
Laws don't work that way however.
Re: (v4lu3s)
I'm with willie on this one. This is an accurate statement.
cool guy name
Re: (DarkKnight1)
Laws don't work that way however.</TD></TR></TABLE>
Not starting a pissing match but if you went to a state inspector(a legit one) and told him that you have a 93 motor in a 2000 car would he care?
Re: (walker111)
The thing is, in connecticut on obdII, they hook up the scan tool. Since I have an obdI ecu, it gives a "link error". With a link error, they will know something is amidst. Either way, the car won't pass, but will they pop the hood and check? I think probably not. I don't know anyone that does the inspections, and it's a bit late to make a friend of one enough to pass me. I'd put the f23 back in, but I sacrificed the harness to build the h22 one.
91EFB20
05-14-2009 07:33 PM
leira619
12
05-10-2006 04:50 PM
racer_X_123
14
08-31-2004 03:58 PM
