Where do these VACUUM HOSES go??
Below is a picture of the 97 gsr motor going into an ek. Where would these two with the red arrows pointing at them go?
Re: Where do these VACUUM HOSES go?? (turbogixxer)
Thanks for the hose diagram, but this ek's "purge control diaphragm valve" on the charcoal canister only has one nipple instead of two like in the above diagram....here it is:
so I was going to plug one end of the EVAP solenoid into that canister and the other end to the nipple above the throttle body:
But this still leaves no place for this other little nipple on the intake manifold in the picture below:
Where would this one go??
Re: Where do these VACUUM HOSES go?? (xsiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsiv »</TD></TR><TR><TD CLASS="quote">
Just block this vaccum line off.
It won't prevent your car from running or throwing a check engine light.
Either that or get a charcoal canister from an OBD2 integra.
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: Where do these VACUUM HOSES go?? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
Either that or get a charcoal canister from an OBD2 integra.</TD></TR></TABLE>
PSI Racing
10
01-27-2020 04:28 PM
VI Boost
12-13-2009 12:42 PM
