USDM b16a2 head on JDM B16a short block
ive been trying to look for a usdm 99-00 si b16a2 short block and have been having bad luck. ive always been able to find plenty of JDM b16a short blocks though.
what would i need to do in order to use the usdm 99-00 si b16a2 head with the JDM b16a short block?
Re: USDM b16a2 head on JDM B16a short block (spidermancivic)
Completely interchangable,bolts right on.If your still using the crank angle sensor you will need a few parts near the balancer.
Glenn
Glenn
Re: USDM b16a2 head on JDM B16a short block (NJIN BUILDR)
exactly what parts? isnt the crank angle sensor on the oil pump? so i just switch the oil pump from the usdm to the jdm block?
do i have to switch engine accessory parts from the usdm a2 to the jdm b16?
ex. alternator, dizzy, injectors, ac, PS?
Nameless Warrior
14
11-15-2006 05:26 PM
