Noobie with some redundant questions
Noobie with some questions
Specs: 98 civic hx, 94 jdm gsr engine: i/h/e, lightweight crank pulley/flywheel.
I want to get a set of skunk 2 stage 2 cams for my car. I know I will have to get springs/retainers etc. I know I will need cam gears. Will I need anything else for these cams to work well? What I am wondering is do I really need vafc or similar for tuning?
What is the cheapest way to get rid of the speed limiter? Without losing v-tec or anything like that.
I have 2.5 inch custom bent exhaust with a v-force muffler. Is this setup alright for my car? From what I've been reading the exhaust diamater may be a little to large.
I've got an "ebay special" lightweight crank pulley. Is this bad for my crank or any other part of my engine ?
I know all of these topics have been talked about before but I want to have specific answers to my setup. Any and all help is very much appreciated.
Thanks
98civic94gsr
Modified by 98civic94gsr at 7:35 PM 4/3/2005
Thanks
98civic94gsr
Re: Noobie with some redundant questions (dreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer »</TD></TR><TR><TD CLASS="quote">I definitely would not use a cheap crank pulley off of ebay.
get Hondata.</TD></TR></TABLE>
I second that.Use the stock balancer and cam gears and use the money for the Hondata.
Glenn
Glenn
Re: Noobie with some redundant questions (NJIN BUILDR)
What would you recommend for a crank pulley, I would like it to be lightweight. Also where is the cheapest place to get it?
Anyone out their who can answer any of those other questions??
Raced a 99 prelude the other night with intake and catback. I had him by out 2-5 carlengths at 100 mph. I thought he would have done a lot better being he comes stock with 200 horsies stock. I guess it was because be weighs like 400 lbs more and redlines at like 6800. I had about a car lenghts on him shifting into third. Once I hit third I took a couple more car lenghts on him and then shut her down. First real race(if you want to call that real). My start sucked so bad. I probaly bounced it off the rev limiter 5 times before I got traction and took off.
Alright I'm going on and on.
Thanks for help on the crank pulleys,
98civic94gsr
98civic94gsr
Re: Noobie with some redundant questions (98civic94gsr)
Just use the stock pulley(balancer).Its real cheap because you already own it.Light weight pulley will not give you any more power.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr »</TD></TR><TR><TD CLASS="quote">What would you recommend for a crank pulley, I would like it to be lightweight. Also where is the cheapest place to get it?</TD></TR></TABLE>
unorthodox racing makes these. use at your own risk. they have been blamed for screwing up people's blocks. my buddy has one on his GSR, no problems so far.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr »</TD></TR><TR><TD CLASS="quote">I guess it was because be weighs like 400 lbs more and redlines at like 6800.</TD></TR></TABLE>
wrong. stock ludes make peak power around 7400-7600 (stock tach is flaky) and fuel doesn't cut off until slightly past 8000 rpm. I would still give you the handicap in that race.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98civic94gsr »</TD></TR><TR><TD CLASS="quote">I probaly bounced it off the rev limiter 5 times before I got traction and took off.</TD></TR></TABLE>
lol learn to drive man
Well I just bought a stock jdm c. pulley for a 1.99. Gotta love ebay.
Well anyone have any answers to some of my other questions.
Thanks again guys,
98civic94gsr
Thanks again guys,
98civic94gsr
