Vtec wiring
Old Mar 21, 2005 | 09:20 AM
BoOstInHaRd's Avatar
Default Vtec wiring
I searched in the obvious thread to look in and didn't find a good enough explantion. So maybe someone can help me out and provide some pictures of the wires needed to be run. BTW I have a eg.
Old Mar 21, 2005 | 10:21 AM
Katman's Avatar
Default Re: Vtec wiring (BoOstInHaRd)
have a looksy on my tech site for wiring info (see link in sig)...
Old Mar 21, 2005 | 03:06 PM
Default Re: Vtec wiring (Katman)
Very helpful^ but where I'm having a hard time is where do the wires have to be run in the engine bay.
Old Mar 22, 2005 | 12:43 AM
Db1_77's Avatar
to your vtec solenoid and oil pressure sending unit
Old Mar 22, 2005 | 05:59 AM
Default Re: (hatch77)
Wheres the vtec oil pressure wire located in the engine bay. I know where the vtec solenoid is but not oil pressure sending unit.
Old Mar 22, 2005 | 06:57 AM
Katman's Avatar
Default Re: (BoOstInHaRd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstInHaRd &raquo;</TD></TR><TR><TD CLASS="quote">Wheres the vtec oil pressure wire located in the engine bay. I know where the vtec solenoid is but not oil pressure sending unit.</TD></TR></TABLE>
the VTPS (vtec (oil) pressure switch) is the green plug on your VTEC solenoid; the other wire is for the VTEC solenoid itself (single wire).
Old Mar 22, 2005 | 07:29 AM
Default Re: (Katman)
Ok, now I understand but whats confusing me is it says in the sticky about h22 to civic to run the blk/blu wire (vtec oil pressure) to the d6 pin on the ecu. So where is this wire.
Old Mar 22, 2005 | 08:56 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstInHaRd &raquo;</TD></TR><TR><TD CLASS="quote">Ok, now I understand but whats confusing me is it says in the sticky about h22 to civic to run the blk/blu wire (vtec oil pressure) to the d6 pin on the ecu. So where is this wire.</TD></TR></TABLE>
you have to completely add this wire if you have a non-vtec civic/integra. Meaning you need to run a wire from the D6 pinout, through your firewall, and out to the VT solenoid.
Old Mar 22, 2005 | 09:25 AM
Ok, so I have to run one from the d6 pin, one from the a4 pin and a ground all to the VTsolenoid.
Old Mar 22, 2005 | 09:41 AM
Katman's Avatar
now yer gettin it
Old Mar 22, 2005 | 02:25 PM
Do you have a pic?
Old Mar 22, 2005 | 02:49 PM
Katman's Avatar
Old Mar 23, 2005 | 08:53 AM
Sorry but I have no idea what that is? So I'm lost again.
Old Mar 23, 2005 | 09:27 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOstInHaRd &raquo;</TD></TR><TR><TD CLASS="quote">Sorry but I have no idea what that is? So I'm lost again. </TD></TR></TABLE>
heh, i was being a dick, its a picture of a 'pic'.
you want a picture of an ecu pin??
I assume you've never wired anyting into your ecu plugs before eh?
Old Mar 23, 2005 | 01:03 PM
No the vtec wiring that goes to the VT solenoid.
Old Mar 23, 2005 | 01:54 PM
IHateJDM's Avatar
only one wire goes to the solenoid. 2 wires for pressure switch, one hot, one ground. With a p28 you can ground the pressure switch to the car, but with a p13 the ecu looks for it. P28 locations should be the same (A4 and D6).
OBD1 P13 Pinout Guide
Contact Color Description
A1 brn Injector #1
A2 yel Injector #4
A3 red1 Injector #2
A4 grn/yel VTEC Solenoid Valve
A5 blu Injector #3
A6 or/wht HO2S heater coil
A7 grn/blk1 PGM-FI Main Relay coil
A8 grn/blk2 Shorted to A7
A9 blk/blu IAC Valve
A10 - -
A11 red2 EGR Control Solenoid
A12 blu/red Condenser Fan Relay
A13 blu/wht MIL
A14 - -
A15 red/blu A/C Clutch Relay
A16 wht/grn Alternator
A17 pink IAB Solenoid Valve
A18 - -
A19 wht Intake Control Solenoid Valve
A20 red/grn EVAP Purge Control Solenoid
A21 yel/grn1 ICM
A22 yel/grn2 Shorted to A21
A23 blk1 GND
A24 blk2 GND
A25 yel/blk PGM-FI Main Relay (power)
A26 blk/red VTEC Pressure Switch (GND)
B1 yel/blk PGM-FI Main Relay (power)
B2 brn/blk GND
B3 - -
B4 - -
B5 blu/blk To A/C Switch
B6 - -
B7 - -
B8 red/grn PSP Switch
B9 blu/red Starter Cut Relay
B10 orn2 VSS
B11 orn3 CYP
B12 wht CYP
B13 orn/blu TDC
B14 wht/blu TDC
B15 blu/grn CKP
B16 blu/yel CKP
D1 wht/yel Battery
D2 grn/wht1 Brake Switch
D3 red/blu KS
D4 brn/wht SCS
D5 - -
D6 lt blu or lt grn VTEC Pressure Switch
D7 lt grn/red Data Link Connector
D8 - -
D9 wht/red ALT
D10 grn/blk ELD
D11 red/blk TP Sensor
D12 wht/blk EGR Valve Lift Sensor
D13 yel/blu ECT Sensor
D14 wht HO2S Sense
D15 red/yel IAT Sensor
D16 - -
D17 wht/blu MAP Sensor
D18 - -
D19 red/wht EGR Valve Lift Sensor
D20 yel/wht TP Sensor
D21 blu/wht MAP Sensor
D22 grn/wht2 TP Sensor
Old Mar 24, 2005 | 10:34 AM
Thanks ^
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
wu tang
Jan 2, 2003 05:36 PM
