b18a into a 89 crxsi cooling sensor/harness problem, please help
Old 03-20-2005, 06:34 AM
yoursupinehead's Avatar
Default b18a into a 89 crxsi cooling sensor/harness problem, please help
my crx harness doesn't have a plug for the coolant sensor on the t-stat housing any thoughts on remedying this? or a site with a how to. btw: i am also doing a obdo to obd1 swap at the same time using a vtec frog jumper harness
here is a pic of the offender:
Modified by yoursupinehead at 8:20 AM 3/20/2005
Old 03-20-2005, 07:30 AM
Import Tuna's Avatar
Default Re: b18a into a 89 crxsi cooling sensor/harness problem, please help (yoursupinehead)
Swap out the cooling sensor that was on the original engine. the thread/diameter sizes should match and it will give you the same plug that you started with.
IT
Old 03-20-2005, 07:41 AM
Default Re: b18a into a 89 crxsi cooling sensor/harness problem, please help (Import Tuna)
its not that the plug doesn't match, it's that it doesn't exist on the old motor (sohc zc) there is no sensor on the waterneck on my zc.
Old 03-20-2005, 05:59 PM
Old 03-21-2005, 03:23 AM
monday morning
Old 03-21-2005, 12:56 PM
c'mon
Old 03-21-2005, 09:24 PM
88ED8's Avatar
That sensor is for the fan switch. on your old motor it is the two wire sensor by the oil pressure sensor you just have to relocate it to the water neck. find a plug that fits and use it when you rewire it to the new location
Old 03-21-2005, 09:26 PM
88ED8's Avatar
And your grounds should be on the other side of the t-stat housing.
Old 03-22-2005, 03:56 PM
Default Re: b18a into a 89 crxsi cooling sensor/harness problem, please help ('89ED8)
i already fixed the grounds, thanks for the help
Old 03-23-2005, 12:31 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’89ED8 &raquo;</TD></TR><TR><TD CLASS="quote">That sensor is for the fan switch. on your old motor it is the two wire sensor by the oil pressure sensor you just have to relocate it to the water neck. find a plug that fits and use it when you rewire it to the new location </TD></TR></TABLE>
Extend the old wires to the new location.
jemo1
06-05-2013 05:55 PM
justdoinme23
06-21-2011 01:12 AM
soon2befasst
08-25-2010 02:43 PM
mymeatb18"
01-29-2005 12:23 PM
(JON)
12-03-2003 06:05 AM
Quick Reply: b18a into a 89 crxsi cooling sensor/harness problem, please help
