used jdmb18c from H-MOTORS......is it safe to install......
This motor from H-motors will have around 40,000 miles on it. Is it safe to install a racing flywheel on such a used motor? I will have simple bolt-on's and NOTHING serious for quite some time.....so i think the motor is a durable enough model. Also.....i have been running high octane in my car ever since I installed supercharger.....so will a new fuel filter be necessary?......it has like 50,000 miles on it right now, but it has ALWAYSS been high octane. Thanks guys.
Re: used jdmb18c from H-MOTORS......is it safe to install...... (kidkanedtx)
yes, you will be fine with the flywheel. even premium gas is dirty, i would replace the fuel filter, but you don't HAVE to. it's good maintenance.
Re: used jdmb18c from H-MOTORS......is it safe to install...... (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">yes, you will be fine with the flywheel. even premium gas is dirty, i would replace the fuel filter, but you don't HAVE to. it's good maintenance.</TD></TR></TABLE>
agreed/ relatively cheap...and if your concerned bout it you might as well.
whoobeedoobee
18
08-05-2003 03:33 PM
