B18b swap info needed.
Ok I have a 98 Civic LX auto and I'm going to swap a B18b w/ 5-speed in the next few weeks and need some answers about the swap.
1. can I use my stock engine harness for teh swap
2. what OEM mounts do I need for the swap(part #'s will be help full)
3. will the stock shift linkage(from the b18b) work in my car or do I have to get the HASPORT one.
THANX
THANX
Re: B18b swap info needed. (six7one)
1. just go to hasport.com for the engine mount kit, it will include everything you need.
2. yes you can use your existing harness just extend plugs as necessary
3. You can use any 94+ 5spd integra shift linkage, d series will not work without modification
Re: B18b swap info needed. (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 »</TD></TR><TR><TD CLASS="quote">1. just go to hasport.com for the engine mount kit, it will include everything you need.</TD></TR></TABLE>
There is no sense to buy aftermarket mounts when you can easily bolt that swap in with 100% OEM mounts and brackets. You will need a 99-00 Si rear bracket and driver's side engine bracket. You will also need a stock 96-00 Civic manual upper tranny mount. If the swap comes with all the other's, then that's it.
Re: B18b swap info needed. (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
There is no sense to buy aftermarket mounts when you can easily bolt that swap in with 100% OEM mounts and brackets. You will need a 99-00 Si rear bracket and driver's side engine bracket. You will also need a stock 96-00 Civic manual upper tranny mount. If the swap comes with all the other's, then that's it.</TD></TR></TABLE>
With the picture below, would that be part # 4 and 7??
Xgen
14
06-04-2005 08:24 AM
intezn
07-21-2003 04:01 PM
