99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring.
Old 03-30-2005, 03:55 AM
dwnthehatch's Avatar
Default 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring.
I have read 20+ pages of threads here and cannot come up with an answer.
I swapped a 99 b16a2 (obd2b) into a 99 civic dx. I used the b16a2 engine harness and stock 99 B16a2 ecu. All I have left to do is wire up the secondary o2 sensor to the ecu since the wiring for that sensor is in the dash harness of a si. I'm still using the DX dash harness.
The oem secondary o2 sensor I have is wired like this:
GRN WHT
BLK BLK
Can anyone tell me where each wire is supposed to go ino the ECU? I saw a few diagrams but I understand what wires go where.
Modified by dwnthehatch at 3:40 PM 3/31/2005
Old 03-30-2005, 08:53 AM
Default Re: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring. (dwnthehatch)
Adding some pics:
Old 03-30-2005, 09:08 AM
EE_Chris's Avatar
Wht - A23
Grn - C18
Blk (O2 heater control) - A8
Blk (O2 heater supply) - use a switched +12v. Factory has got this off of connector C115 which also supplies power to the EVAP purge solenoid (among other things).
Old 03-31-2005, 11:41 AM
Default Re: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring. (EE_Chris)
Thanks! No CEL!!
Old 06-07-2005, 02:50 AM
kinvid22's Avatar
I'm having the same problem. How do I physically wire it to my ecu?
Old 06-09-2005, 09:39 PM
kinvid22's Avatar
Default Re: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring. (kinvid)
(viewed from the pin side on the male plug)
For the 96-98 OBDII ecu:
1 (green) goes to D13 (green/ blk) for sensor ground
2 (white) goes to D14 (white/ red) for sensor signal
3 (blk/white) goes to A5 (blk/ white) for heater signal
4 (blk/yellow) needs to "TAP" into A11 (yellow/ blk) for 12v power
So I make my own wires from the secondary o2 sensor, extend it long enough, and "splice" them into the engine harness wires right before the "A" and "D" plugs at these location: D13, D14, A5, A11 ???
Old 07-10-2005, 02:13 PM
dynamo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the same problem. How do I physically wire it to my ecu?</TD></TR></TABLE>
I have the same question. I *kind of* understand which wire is supposed to go where, but I don't understand how to actually connect it to the ECU?
Old 07-11-2005, 08:23 AM
EE_Chris's Avatar
Default Re: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring. (dynamo)
The ECU has connectors that have wires with pins crimped onto their ends that secure them into the ECU connector.
If you need to connect up to the ECU but do not presently have a wire in that particular spot, you will need to find another harness (from a junkyard perhaps) and then remove a wire with crimped pin from it. Then just go ahead and solder up whatever it is you need to that pigtail and insert into the needed ECU connector spot.
If there is already a wire in the particular spot, then just cut and solder.
Old 08-09-2005, 11:56 AM
dynamo's Avatar
SO I am still having a hard time figuring out where to connect the 12V wire on the o2 sensor.
THe post above says: 4 (blk/yellow) needs to "TAP" into A11 (yellow/ blk) for 12v power
But A11 is not noted on Katman's diagram above. Is it safe to assume it's the wire to the right of A10? Currently I don't think I have a wire going to that location in the harness. So, do I still wire it into that spot?
Old 08-09-2005, 11:09 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamo &raquo;</TD></TR><TR><TD CLASS="quote">SO I am still having a hard time figuring out where to connect the 12V wire on the o2 sensor.
But A11 is not noted on Katman's diagram above. Is it safe to assume it's the wire to the right of A10? Currently I don't think I have a wire going to that location in the harness. So, do I still wire it into that spot?</TD></TR></TABLE>
No, A10 is for the service connector. Under the intake manifold, there is a connector with many yel/blk, blk/yel. They are all 12v switched power. Tap into one.
Old 08-09-2005, 11:55 PM
dynamo's Avatar
Default Re: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring. (Turbogixxer)
Thanks for the reply Turbogixxer
Ok I probably sound like a total dumbass, but I can't find any of the connectors you are talking about. Is there nothing on the harness that I can use, or anything near the harness?
Old 08-10-2005, 01:37 PM
EE_Chris's Avatar
Drivers side, near the firewall, you'll see a gray 10-pin connector. There is a Blk/Wht wire that runs through there which feeds the connector that turbogixxer is referring to. Grab a multimeter to test and make sure.
Old 09-13-2005, 08:55 AM
dynamo's Avatar
OK, I got the secondary wired in and its working fine. However, I am now getting the P0132 code, which indicates that the primary o2 sensor wiring is screwed up.
Could someone please let me know where the wires from the primary o2 sensor plug go (like the diagram above for the secondary o2 sensor wiring)?
TIA
Old 02-05-2007, 04:27 PM
wtfitzsoda's Avatar
up for reference!!
Old 02-27-2008, 12:12 PM
ghettochild's Avatar
Default Re: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring. (wtfitzsoda)
bump for more info on the +12v
dokdok
10
07-15-2008 01:48 PM
ixoiiiiviviiivi
04-02-2008 11:31 PM
EK9_Hatch
11
03-23-2006 12:00 PM
El_Capitan
01-15-2006 11:42 AM
kyden
09-28-2004 04:18 PM
Quick Reply: 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring.
