IACV - differences between OBD0 and OBD1
Old Mar 25, 2005 | 06:59 AM
Brian_92GSR's Avatar
New User
Default IACV - differences between OBD0 and OBD1
I just got done putting an OBD1 B18A in my '91 Integra. I kept the stock harness, and switched both of the coolant temp sensors which had different connectors. The IACV, however, had a different bolt pattern on the IM, so I used the OBD1 version. Is there any electrical difference in how they both work? I do have a OBD1 ECU I can switch to, but they may introduce new problems, such as the O2 sensor change.
Old Mar 25, 2005 | 11:24 PM
eda6's Avatar
Default Re: IACV - differences between OBD0 and OBD1 (Brian_92GSR)
They're electrically identical. I've ran a 95 b16 iacv with my obd0 pr3. Switched to an obd1 p28 ecu, iacv still works w/o problems.
efiliated
Jun 6, 2011 04:04 PM
xsi90teg
Feb 17, 2009 08:18 PM
xsi90teg
Jan 29, 2009 07:32 PM
ViperRedCRX
May 19, 2003 01:01 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
