HF control arm swap?
Re: HF control arm swap? (eda6)
i will soon be pulling my gsr swap out of my vx and into a hf. what i read was you need to run different control arms. also i have extended lugs on my vx, that i would like to swap over.
Re: HF control arm swap? (WhiteVX)
you don't need to run differnet control arms you need the crx si knuckle and hubs because they will except the b series axles with a little bit of work, or you could just run integra front knuckles and hubs off of a DA.
