crx poor itr setup, knock sensor code, octane or plugs?
91 crx with poor man itr set up, compression at 11.5 :1, running 94 octane. getting a knock sensor and its retarding my timing. car idles fine, runs fine under higher open throttle and wide open throttle, and at idle. but at like cruising throttle it misses like mad! i will check the knock sensor today, but does anyone have any suggestions other than if its not the knock? (like changing plug tempatures?)
