96 usdm h22a (obdII) into 92 civic hatch
who here has something like this obd2h22 in a 5th gen hatch?
and what problems did you encounter mainly with this swap.
did you guys also skimp and convert to obd1? and use your civic harnesses or what?
also what ecu are most of you running, i assume p72...?
Re: 96 usdm h22a (obdII) into 92 civic hatch (hybridvteceg)
I put a 97 h22a4 in my 96 ex, Biggest problem for me would have to be the wiring, cause I had it converted to OBD1 using my stock harness. I was told that keeping it obd2 would slack on some of the power, and in the future would end up wanting to convert it anyway. So I went OBD1 using a P13 ecu. Also I had to fabricate a steel plate for the accord mid shaft to bolt up to the block. But you wont have to do that. I dont have any power steering, or A/C, (Do plan on it in the future though) so thats a little easier for my swap. Those are the only problems I really had. Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">who here has something like this obd2h22 in a 5th gen hatch?
also what ecu are most of you running, i assume p72...?</TD></TR></TABLE>
mainly these questions...
Re: 96 usdm h22a (hybridvteceg)
obd2F20B in 93 DelSol (it should be the same i think)
used original obd1 wiring and added (VTEC, KS, O2 and Oil PS)
replaced obd2 injectors with h22 obd1's
P30 modified with uberdata
integra 91 axles
integra 91 axles
Modified civic harness
OBD2 to 1 conversion harness + OBD1 P13
ekbrandon
02-19-2018 06:55 AM
