Are P13s and P28s "hot swappable?"
I have a P13 running in my Sol, the factory one that came with my H22A. I am looking to get my old P28 reprogrammed to emulate the P13 but without the EGR and knock sensors (and fuel cutoff). Could I just unplug one ECU and plug in the other? I'll admit that I didn't do the H22A swap myself, so I was wondering if this can be done that easily.
Read through my post.
https://honda-tech.com/zerothread/1676983
Should answer all your questions. All in all.. 0bd1 with 0bd1 answer is a yes.
-Jason
-Jason
Re: Are P13s and P28s "hot swappable?" (SolAssassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolAssassin »</TD></TR><TR><TD CLASS="quote">I have a P13 running in my Sol, the factory one that came with my H22A. I am looking to get my old P28 reprogrammed to emulate the P13 but without the EGR and knock sensors (and fuel cutoff). Could I just unplug one ECU and plug in the other? I'll admit that I didn't do the H22A swap myself, so I was wondering if this can be done that easily.</TD></TR></TABLE>
try Pming Katman - i know he does ecu chips
Yes, you can just swap a P28 to it. Although a factory P28 will make the engine run extremely lean and not run right..
All you need is a chip or basemap of the prelude's fuel & timing maps.
HTH.
HTH.
Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">FYI: "hot-swappable" would mean that you could remove said ECU while the vehicle was running without interupting the vehicles operation. No it is not hot-swappable....</TD></TR></TABLE>
i know that. hence, the quotation marks on hot swappable
