b18c vtec problem
Old Jul 1, 2006 | 03:55 PM
jdmgsrteg's Avatar
Default b18c vtec problem-tested everything! read inside
ok here is all the info on the car
1997 integra ls
b18c jdm gsr swap. its obd2 and has a usdm obd2a ecu.
vtec is kicking in at 4500rpm's. i kinda don't get how this is possible when the ecu can't be chipped. i tapped a led into the vtec solenoid wire to make sure i was right at when it was comin in. when it hit 4500 rpms it came on.
the oil level is fine.
wiring and everything is good.
the ground for the vtec switch is on the block.
i have and a/m oil press gauge.
idle oil pressure is 25-30 psi
right around 3 grand the oil psi jumps to 80 and anywhere after 3 grand it stays between 50 and 70 psi.
Modified by jdmgsrteg at 12:11 PM 7/2/2006
Old Jul 2, 2006 | 06:22 AM
jdmgsrteg's Avatar
Default Re: b18c vtec problem (jdmgsrteg)
bump...no one?
guess i'll just try swapping ecus
Old Jul 2, 2006 | 09:15 AM
JasonST's Avatar
Yeah that does seam a little low, just to make sure, u doin't have a vafc do u? Yeah I'd try a diff ecu cause it seams like everything else is fine. O and are u getting and cels? Good luck.
Old Jul 2, 2006 | 09:23 AM
jdmgsrteg's Avatar
Default Re: b18c vtec problem (JasonST)
there was a vafc on it for a while but was takin out. but i made sure all the wires are correctly back in place.
Old Aug 8, 2006 | 03:15 AM
BigRonDawg's Avatar
bump, my b18c does this too... i thought it was weird too... i have no cells either. i'm researching now.
Old Aug 8, 2006 | 03:18 AM
BigRonDawg's Avatar
Default Re: b18c vtec problem (BigRonDawg)
https://honda-tech.com/zero...10696
https://honda-tech.com/zero...73709
it's everywhere... guess we are ok bud.
Old Aug 8, 2006 | 07:35 PM
pennies_hatchie's Avatar
The B18C (non-R) engages VTEC at 4400 RPM, and opens the high-RPM intake manifold runners at 5800 RPM
Old Aug 9, 2006 | 07:03 PM
Slopoke's Avatar
Default Re: b18c vtec problem (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">The B18C (non-R) engages VTEC at 4400 RPM, and opens the high-RPM intake manifold runners at 5800 RPM
Yep.
Did you wire up the IABs?
Old Aug 10, 2006 | 12:59 PM
del_slow420's Avatar
Default Re: b18c vtec problem (Slopoke)
wow.. its called dual stage buterfly... its like duel stages of vtec
dcraige
Engine Management and Tuning
May 28, 2009 06:22 AM
zimmy709
Aug 10, 2008 02:08 PM
robin_yanani
Jan 12, 2006 01:38 AM
tnd2gen
Oct 27, 2004 07:38 PM
1insaneR
May 9, 2004 05:52 PM
