RHD engine in LHD car!
Old Jul 5, 2006 | 12:07 PM
eriknn's Avatar
Default RHD engine in LHD car!
What troubles will I run into when putting a B16A2 from a 98 RHD civic into a 97 LHD civic? How will the wiring harnesses fit?
Old Jul 5, 2006 | 12:30 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: RHD engine in LHD car! (eriknn)
everything should be the same with the exeption of the sensors you need to wire in
Old Jul 5, 2006 | 12:46 PM
eriknn's Avatar
Default Re: RHD engine in LHD car! (2FAST4U831)
Ah, that's nice.. But what do you mean with "the sensors I need to wire in"?
Old Jul 5, 2006 | 01:03 PM
2fast4u831's Avatar
I'm really 2slow
vtec solenoid, vtec oil pressure and knock unless your car already had a vtec engine.
Old Jul 5, 2006 | 01:13 PM
eriknn's Avatar
Ah.. I'm using the harness from the RHD car... I have a special european version, so I can't use the old harness...
Old Jul 5, 2006 | 03:03 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eriknn &raquo;</TD></TR><TR><TD CLASS="quote">Ah.. I'm using the harness from the RHD car... I have a special european version, so I can't use the old harness...</TD></TR></TABLE>
If you're car is not RHD, then I would not recommend using the RHD harness. It's much easier to use a LHD harness and plug it up.
Old Jul 6, 2006 | 10:19 AM
vart's Avatar
Default Re: RHD engine in LHD car! (poison)
yeah everything will be *** backwards. Get yourself a USDM B16 wiring harness, or even a d16 wiring harness. It will make it soo much easier.
Old Jul 6, 2006 | 11:32 AM
b16adx's Avatar
use youer wiring harsess from your car..depeneding on what model you have and just make the necessary additions to your harness
Old Jul 6, 2006 | 12:34 PM
eriknn's Avatar
Default Re: RHD engine in LHD car! (b16adx)
Using the old wire harness is not an option... I may be stupid, but I don't really understand why it would be "backwards"?
Old Jul 6, 2006 | 12:48 PM
vart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eriknn &raquo;</TD></TR><TR><TD CLASS="quote">Using the old wire harness is not an option... I may be stupid, but I don't really understand why it would be "backwards"?</TD></TR></TABLE>
Because everything on a RHD car is on the opposite side of a LHD car, ex: battery, fuse box, car harness plugs....everything. You NEED a LHD harness.
Old Jul 6, 2006 | 12:50 PM
eriknn's Avatar
Default Re: RHD engine in LHD car! (vart)
And where could I get one of those?
Old Jul 6, 2006 | 01:14 PM
vart's Avatar
what motor is in your car now?
Old Jul 6, 2006 | 01:37 PM
eriknn's Avatar
D14A4 If using the RHD harness, wouldn't the only problem be for some wires to reach their "destinations"? For instance if the alternator is further away from the battery now than in the RHD car it would need to be lenghtened? However, many wires would be longer, or jsut the same, wouldn't they?
Old Jul 6, 2006 | 01:57 PM
vart's Avatar
if using a RHD harness youd have to lengthen almost all of the wires. Fin yourself a LHD OBD2 B16 harness or D16, and youll be good.
Old Jul 6, 2006 | 02:59 PM
b16adx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eriknn &raquo;</TD></TR><TR><TD CLASS="quote">D14A4 If using the RHD harness, wouldn't the only problem be for some wires to reach their "destinations"? For instance if the alternator is further away from the battery now than in the RHD car it would need to be lenghtened? However, many wires would be longer, or jsut the same, wouldn't they?</TD></TR></TABLE>
Yea in theory you could do that but you would have one hell of a mess on your hands not to mention do you really realize how many wires you would have to lengthen...hell just go to a junk yard and pull a harness from a 92-95 civic ex and use that
Old Jul 6, 2006 | 03:04 PM
eriknn's Avatar
Okay, I'm looking for an EK4 LHD wiring harness then.. Anyone got one?
Old Jul 6, 2006 | 07:00 PM
94eg!'s Avatar
#1 Super Guy
Loved
FYI: The motors are the same weather they are from a LHD car, or a RHD car. All the sensors on the motor are in the exact same place. The problem is where the engines wire harness connects to the car itself. Since the Battery, ECU & fuse box are all on opposite sides in a RHD chassis, all the chassis plugs will be on the wrong side. Using your stock LHD harness & adding in the extra plugs & wire from the RHD harness, you can easily build yourself a fully functional LHD VTEC harness.
Old Jul 6, 2006 | 11:39 PM
eriknn's Avatar
Default Re: RHD engine in LHD car! (94eg!)
Hmm, yeah, maybe.. I'll just wait for the stuff to arrive and I'll look at it... Got to be some easy way to do it
Old Jul 7, 2006 | 06:28 AM
poison's Avatar
It IS easy...
Using a RHD harness would make it the most difficult.
Old Jul 7, 2006 | 08:12 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">It IS easy...
Using a RHD harness would make it the most difficult. </TD></TR></TABLE>
RHD harnesses are great to chop up for plugs and wiring. other than that they are worthless.
Old Jul 14, 2006 | 06:52 AM
eriknn's Avatar
Default Re: RHD engine in LHD car! (v4lu3s)
Okay, seems I'll be using the original harness.. Found out it's only 12-13 wires I'll have to add, and that's not as bad as I thought.. Guess it's time for chopping uyp the RHD harness then :D
Perkul8r
May 14, 2009 09:14 PM
PaChiLa Leader
Nov 8, 2008 10:52 PM
ColinSiR
May 11, 2008 12:19 PM
whiteferio
Dec 25, 2006 06:05 PM
swaplighter
Mar 3, 2003 04:23 PM
