JDM p30 or USDM p30?
Which would be better for a b16a2 swap into an EG? Right now its running on a p72, but its for a 1.8 motor so im sure its running rich as hell.
Re: JDM p30 or USDM p30? (GarageTech)
the usdm p30 has no speed govenor while the jdm one does i forget where it is-
either one will work
or you can chip an ecu and have a program burned to a chip made for your car/motor
#1 Super Guy
Re: JDM p30 or USDM p30? (amy)
I would use the US computer because it will bolt into the car like stock (if it's an OBD-1 car)... If the motor is JDM, you will have to bypass the VTEC pressure switch, but that would be the case with the P72 you already have (if it's a US P72)...
Re: JDM p30 or USDM p30? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">I would use the US computer because it will bolt into the car like stock (if it's an OBD-1 car)... If the motor is JDM, you will have to bypass the VTEC pressure switch, but that would be the case with the P72 you already have (if it's a US P72)...</TD></TR></TABLE>
he said it's a b16a2 so that means it's a usdm motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageTech »</TD></TR><TR><TD CLASS="quote">Which would be better for a b16a2 swap into an EG? Right now its running on a p72, but its for a 1.8 motor so im sure its running rich as hell.</TD></TR></TABLE>
either one in stock form will work to run your motor, but as Amy says, the JDM ecu will have a speed limiter (at about 115mph). You can have either ecu reprogrammed as mentioned.
Running the P72 ecu isn't running that rich on a B16..
the shitty thing about a P72 is the early VTEC crossover point of 4400-4800rpm. That puts a dip/bog in the power band. If you had a VTEC controller and raised VTEC to abeut 5300-5500rpm, then you'd be back on track...
Ricky Ng
05-18-2019 07:23 PM
