Having trouble checking Codes in OBD1 CRX
Old Jul 2, 2006 | 11:22 AM
G0crxG0's Avatar
Default Having trouble checking Codes in OBD1 CRX
So I was told The plug on the driverside with a yellow rubber cover, was the spot for jumping the ecu to show codes.
I jumped it while the car was in the 2nd ignintion spot, and it didnt show the codes
Then I tried doin it while the car was runnin, and the codes dont show.
Thoughts?
(searched)
Old Jul 2, 2006 | 11:59 AM
v4lu3s's Avatar
RTFM
how was the car converted to obd1? usually the jumper harness has a wire that needs to be grounded to display codes.
Old Jul 2, 2006 | 12:19 PM
JasonST's Avatar
Default Re: (v4lu3s)
U sure it's on the driverside, at least for my car and all honda's i've worked on it's on the passengers side under the glove box. a connector with 2 wires, simply put a paperclip into it grounding both wires together.
Old Jul 2, 2006 | 01:00 PM
G0crxG0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">how was the car converted to obd1? usually the jumper harness has a wire that needs to be grounded to display codes.</TD></TR></TABLE>
It was converted using a Rywire OBD0-OBD1 Jumper harness.
Maybe I should give Ryan a call?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">U sure it's on the driverside, at least for my car and all honda's i've worked on it's on the passengers side under the glove box. a connector with 2 wires, simply put a paperclip into it grounding both wires together.</TD></TR></TABLE>
From my understanding, that is where it is on naturally OBD1 cars.
The connector I'm talking about (the one in the yellow cover) is pretty much identical to the ones I've seen pictured in the threads I found from my search.
I guess I'll give Ryan a call, check under the glove box, and try using an actual paper clip instead of this piece of wire.
IDK if this helps, but when I start up the engine, it starts and idles fine for about 2 seconds, then the idle jumps about 250RPM's and the CEL comes on.
Old Jul 2, 2006 | 04:09 PM
v4lu3s's Avatar
RTFM
one every obd0-1 harness i have used there was a wire that was marked either with a label OR in the isntall instructions and all you had to do was ground it.
video_voide
Dec 17, 2012 11:08 AM
Tanked
Sep 10, 2012 03:30 PM
Sinner
Feb 6, 2006 06:54 AM
zCivic
Feb 9, 2003 01:30 PM
