Itr tranny in a gs-r?
when putting a 2000 itr tranny in a 94 gsr what rear motor do i need, because the rear motor mount holes dont line up..I am goin to swap this motor into a eg in a few months...will i use the same mount? Thanks.
Re: (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 »</TD></TR><TR><TD CLASS="quote">same
same doesnt line up...someone told me a 2000 si rear mount will work?
Re: (syn inside)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 »</TD></TR><TR><TD CLASS="quote">same</TD></TR></TABLE>
Use the same bracket. If you're swapping into an EG, you need to use the GSR bracket. Trust me, I have a type r transmission in my EG and I used the GSR bracket. The holes should line up.
Re: (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy »</TD></TR><TR><TD CLASS="quote">Maybe the one you have isn't what you think it is?</TD></TR></TABLE>
yea could be.
yea could be.
Re: (pogeeboy27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogeeboy27 »</TD></TR><TR><TD CLASS="quote">Make sure you also change the rear rubber mount to a GSR one also. The GSR L-bracket won't work with the stock civic rubber mount. You need the GSR one. </TD></TR></TABLE>
I don't know where you heard this from...
he shouldn't have to change out the rear engine mount (rubber), they're all the same between EG & DC2 chassis's.
Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">I don't know where you heard this from...
he shouldn't have to change out the rear engine mount (rubber), they're all the same between EG & DC2 chassis's.</TD></TR></TABLE>
Maybe it was just my car. I dropped a B16A2 and I had to use the GSR rear engine mount. I tried it with the EG rear mount and the holes did not line up. By the way it was a 92 Civic DX.
Re: (pogeeboy27)
Maybe it was just my car. I dropped a B16A2 and I had to use the GSR rear engine mount. I tried it with the EG rear mount and the holes did not line up. By the way it was a 92 Civic DX. </TD></TR></TABLE>
was the EG mount the original one that came with your DX? and was your DX originally an auto?
Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">was the EG mount the original one that came with your DX? and was your DX originally an auto?</TD></TR></TABLE>
Yup I bought my DX bone stock. It was also 5 speed.
Re: (pogeeboy27)
Yup I bought my DX bone stock. It was also 5 speed. </TD></TR></TABLE>
ok yeah, should be the same mount as a 94-01 B-series integra mount...
ezza
09-16-2005 12:07 PM
