what radiator to use with H22 civic with a/c
i wanting to put a/c back in my h22 eg. i know i need to get the hcp bracket first, but can i use a full length radiator from a integra and still have room by mounting the condensor infront of the radiator.
Re: what radiator to use with H22 civic with a/c (speedraycer25)
I would just run a del sol vtec radiator with a slim fan. Because the hcp ac bracket makes it so you can use your stock civic a/c lines.
no you cant run a full length teg radiator.... where do you think the condensor is going to go?
Re: what radiator to use with H22 civic with a/c (fastwanabe)
ya i already have a del sol radaitor in it for about 4 yrs but every once in a while it will over heat in trafffic on a hot humid day
I plan on putting condensor in front of the radiator if i go with a full size rad. What do think
thanks
thanks
i bet there's enough room, depending on what header you use.
put a pusher slim fan on the front of the A/C condensor
on my EK there's TONS of room in front of the engine. i'm not sure on EG tho
explosive
11-01-2003 07:58 PM
chewiejdh
06-29-2003 04:36 PM
