zero oil psi (warm) Please help swapped pumps, pickups, filter, lines...ect
I swapped my B20's oil pump for my old Ls oil pump because I was getting 25ish psi idle untill the engine warmed up than it would drop to ZERO.
I threw a type r filter on it, reworked some turbo oil lines. and still no psi, Soo i did the pump.
But I did notice afew things when I drope the pan
-no metal on magnetic drain plug.
-oil pick up was very clean. (little or no garbage), But pickup was dented a bit near screen, and the oil pan was also dented... Would these two prblems cause a system to have low oil pressure or even starve the pump.??
Re: zero oil psi (warm) Please help swapped pumps, pickups, filter, lines...ect (JDMB20TDA)
i had this issue on a sohc i had ... It the pan smashed against the pick up so tight that it cant get a volume of oil picked up .. to create psi?
i would say .. change the pan and the pick up.. maybe there is something sitting behind the pick up screen..seen that before also.
did u start it with the new pump on it? and no oil PSI?
Re: zero oil psi (bluemax189)
well i had a blox electric gauge and i got scared soo i picked up this mechanical...
I did notice the feed line off the back of the block is kinda bent (should be hard steel)
Re: (douspray)
yea but like i said no metal in the pan + its only got 40K on it...
I highly doubt 2000 mile oil changes and only 40K my motor would be failing....
Re: (PURPLETERROR aka BIGMATT)
10w30, beat the pan out with hammer, and just got new feedline, sooo Im gunna pick up a new mechaniucal gauge today... see what happens
caspers_hatch
11-12-2005 11:37 PM
