no spark on B18cR......
I recently just swapped a 96 B18c spec r into my 99 hatch and used my cx harness from the original d16y7. I spliced the ITR dizzy harness onto the cx harness, color matched, and repin'd the blk/yel ignition input wire. STILL no spark. Im using a OBD2b to OBD2a jumper harness from Locash. I DO have the p73 ecu. If anyone has had this problem or this scenario PLEASE let me know. Also if anyone has the wiring diagram for the ITR dizzy i'd appreciate it.
Thanks alot.
Thanks alot.
Re: no spark on B18cR...... (APCforthewin)
Yea my friend did the same swap and used the cx harness. He had the same prob, but i dunno how he corrected it....ANY HELP ANYONE?? maybe a distriutor diagram??
check the under dash fuses.. and if that dont work check the dizzy with a test light and make sure you have power goin to the dizzy.. if power is going to the dizzy and not comming out then the dizzy is bad.. most likely the module
Int3graz
23
09-26-2011 02:50 PM
Mischief_EG
15
06-15-2004 07:56 PM
b18c5eg
12-23-2002 02:22 PM
