internals on my ITR
internals on my ITR
hey wats goin,I have a built usdm itr w/ 11.2-3.1 compression. i have a p28 chipped ecu,spoon cam gears and a b16 intake mani to make more mid-range and i made 180whp. I am lookin to b a bit faster soo i wanted to know wat everyone would do as far as there head.. i wana get toda,jun or skunk 2 stage 2 cams w/ retainers and springs. I just wana get some opinions on wat would b a better setup for me to make the most potential wheel horse.?.?. let me know wat ya'll think wouod b the best setup
what kind of header do you have? a high end header will net you some more power compared to a lower end one.
cams are also an idea, and witha tune you should make over 200.
just some ideas..
just some ideas..
well my car was just dynoed at the shop n it made 180 like i said to the wheels. the guy there told me he couldnt adjust anythign to get me more whp.. that eveyrthing was perfect my fuel n air..he said only way to go fatser is do my head w/ some cams,retainers n springs..
i wanted to have the shop i brought my car to do hondata n the guy said it wouldnt make any diff w/ my p28 chipped ecu?? bc the car alreayd made great hp for being stock basically he said it wouldnt expand anything else to give me mroe power
Re: (Woogie Ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Woogie Ctr »</TD></TR><TR><TD CLASS="quote"> I just wana get some opinions on wat would b a better setup for me to make the most potential wheel horse.?.?. let me know wat ya'll think wouod b the best setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Woogie Ctr »</TD></TR><TR><TD CLASS="quote"> bc the car alreayd made great hp for being stock basically he said it wouldnt expand anything else to give me mroe power</TD></TR></TABLE>
so what are you really asking here?
i wana know wat would b better toda,jun or skunk 2 stage 2 cams?? which will give me better results.. i was just posting wat the guys told me from the shop where i had the car dynoed
Re: (Woogie Ctr)
You should go back to the ITR intake mani, Skunk2 stage 2 cams and springs with titanium retainers...and port and polish the head and port match the itr mani. what size exhaust do you have? you should also think about bigger injectors, somewhere around 330's, and a bigger throttle body. a clutch and a lightweight flywheel will also help get more of your power to the ground.
Re: (skyline98)
well i plan on doin hondata when i do the head...I have 310cc injectors now.. n i am runnin jdm itr tanny w/ lsd 4.78 final drive w/ like 20k on it...
Modified by Woogie Ctr at 5:21 PM 7/21/2006
Re: (Woogie Ctr)
well I would save up and do all the head stuff at the same time. send it out for port and polish, order the parts when you do so when your head is done you should have the parts by the time it gets back. bolt it all up and go dyno tune it with the Hondata. gauranteed over 200 whp just with that.
Re: (skyline98)
im gonna grab the skunk2 stage 2 cams w/ titanium springs, retainers maybe a thinner head gasket to raise compression lil more, hondata s200 and then prolly a jdm4-1 or rmf header bc they have 2.5inch collector i am running a comp tech which is only 2.25
Re: (skyline98)
ahhh it should b mint when i get it all, but for now i dunno wat to do.. im kinda stuck on ideas and things to do to my hatchie
Re: (vtec2nv)
yeah the all motor forum is mint i just dont use it too much... right now with wat i have i ran 13.7 at 102..but that was my first time at the track and only made 2 passes ever
Re: (Woogie Ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Woogie Ctr »</TD></TR><TR><TD CLASS="quote">yeah the all motor forum is mint i just dont use it too much... right now with wat i have i ran 13.7 at 102..but that was my first time at the track and only made 2 passes ever</TD></TR></TABLE>
