JDM B18b1 & USDM B18b1 swap...
I have a stock LS with the USDM B18b1..
i was shoping around engines... ,and I was wondering if anyoe could give me an Answer to weather the JDM B18b1 drops right in with out any problems.... even when its not USDM.
Re: JDM B18b1 & USDM B18b1 swap... (ek99)
yes, i understand its the same.. I had the feeling it would just droped in. I just get the thought there something im over looking like wiring or somesort of difference in layout maybe...
thank you by the way.
Re: JDM B18b1 & USDM B18b1 swap... (Seto-Initial-B)
Since its the SAME engine, the wiring is the same. The only difference i noticed is that its missing a nipple on the rear of the manifold which i think is for the purge valve. Other than that i'm not sure what you want to know.
What i want to know is just anything that must be done for the swap...
from what your saying its just like replacing it with the USDM engine, and should not have any type of problems with the swap.
BlackThorN
04-19-2004 12:10 PM
