Check List for 94+ LS swap in 92 Civic Hatchback
New User
Whats up guys. This has probably been talked about before. Can someone give me a checklist of all the parts for a LS swap. Just want to make sure i have everything I need here. High Boost Engine modification advice would be helpful to. Thanks
Remy
Remy
Guest
Posts: n/a
Re: Check List for 94+ LS swap in 92 Civic Hatchback (CrucCivicHB)
Do it right the first time.
Get everything from the Integra, and put it in the Civic.
ECU
Engine harness
Axles & halfshaft
All engine mounts
Integra throttle cable (yes, it's different)
P/S pump (if needed)
A/C bracket from 95 delSol DOHC (if needed, buy from the dealer)
Shift linkage & shifter
Header & cat (don't forget the cat, the civic is different)
That is all I can think of.
ECU
Engine harness
Axles & halfshaft
All engine mounts
Dont forget integra radiator hoses. Also make sure the engine comes complete with alternater, throttle body, intake manifold, dist., etc.
If you get the motor and tranny seperate, you may need a clutch and flywheel too.
bap168
09-16-2007 06:33 AM
2006CiViCsI
02-16-2006 09:57 AM
