who has a 1st gen b16 in an EG?
HOw did you guys make the mounts work? I'm going to be using my old hydro b-series tranny. The question is, Did you guys hook up the front mount? The newer models had two mounts, one in the front of the tranny, and the other on the ac and ps bracket. The thing is, does the bracket fit onto the older gen blocks too? Or will I have to custommise one to adapt to the older block? Will my hydro tranny bolt on no problem?
Re: who has a 1st gen b16 in an EG? (Slow_ass_4dr)
yes but only b-series EG (ie. Civic SiR, Del Sol/CRX VTEC SiR or even 94+ integras, 97+ JDM orthia wagon) mounts will work (metal parts, the mounts its self will work from any 92-5 civic (rubber pieces)) ....the upper driver side mount will work from 92+ civics but where it connects to the block this might need to be changed...
New User
there is a small difference between the 94-95 trannys to the 95-2001 trannys. the rear mount for the 94-95 is a little bit smaller than the newer models. so when you are looking for your mounts make it clear what year tranny you have
Re: who has a 1st gen b16 in an EG? (SPOCK)
use GSR mounts all around ..easy answer.
ive done me up a b16a from a non obd car in me old 5G HB..
B16a + 96 GSR electricals +96 GSR injectors+96 GSR fuel regulator + 97 ITR tranny +00 ITR intake manifold
+7lb flywheel + RPS clutch = really good setup ya dick
boosted_dc2
11-29-2004 09:48 PM
