need help with ls swap
Old Apr 16, 2001 | 05:49 AM
gargamel's Avatar
New User
Default need help with ls swap
I recently just dropped a b181b in my 95 civic coupe. It runs right now but when i rev the motor or accelerate it begins to bog. The acceleration is very slow almost feels like i have turbo lag. I t will start slow then speed up quickly. Any comments. TIA
Old Apr 16, 2001 | 10:06 AM
9five1five's Avatar
New User
Default Re: need help with ls swap (gargamel)
check all your electrical connections, distributor, spark plugs, ground wire...
ive never swapped an engine, its just that thats what everyone always says when someone posts this question...
Old Apr 16, 2001 | 10:18 AM
DreamSpeed's Avatar
is your check engine light on? if so then most likely your o2 sensor is not working right or not hooked up right, i had the same problem when i got my b16a swap
Old Apr 22, 2001 | 12:58 PM
jbsadler's Avatar
New User
Did you use the ECU from the b18b1 or the stock ECU that came with the car. I just did this swap in my 95 hatch and used the b18b1 ECU and have no problems.
Blainet96
May 27, 2015 03:28 PM
95slammedEGG
63
Feb 9, 2012 01:44 PM
Shwilson
Nov 30, 2010 03:29 PM
94HatchLS
Oct 11, 2010 07:50 AM
EndlessGarageEG6
Jan 28, 2002 11:44 PM
