All motor question
Old May 6, 2001 | 08:13 PM
CiViC dRaGsTaR's Avatar
New User
Default All motor question
Do you really need to build up your bottom for going all motor? Im talking around 230 hp with a b18c engine. If so, what will i need to get?
Old May 7, 2001 | 05:41 AM
eg6ajk's Avatar
Default waz up...
depends on high much higher you want to rev...no not really needed but polishing, balancing or even knife edging the crank can be an option...
if you are looking for 230 flywheel or about 200whp...then i would do it the following way:
high c/r pistons JDM ITRs or even CTR (a little overkill)
thin spoon or mugen or toda head gsket
Toda C or Jun 3 or other super crazy cams....
completly upgraded valve train (valve springs, retiners)
some port polish on the head maybe 3 or 5 angle valve work
bigger bore TB
lightweight flywheel
if its a GSR motor then Skunk2 manifold
JDM ITR header with 2.5" cat or test pipe or Spoon, mugen or some other quality header
thats how i would build it up....
Old May 7, 2001 | 05:34 PM
Balrog's Avatar
New User
Default Re: All motor question (CiViC dRaGsTaR)
crower.com sells a nice stroker kit.
turn that 1.8 into a 2.2!
Old May 7, 2001 | 07:42 PM
New User
Default Re: All motor question (GSRdreaming)
Im looking to redline at around 9k and make 210hp to the wheels..
Old May 7, 2001 | 10:39 PM
xtrafastcivic's Avatar
don't stroke it stroking doesn't make that much power if you want bigger displacement bore it out or find a b20 block but EG6 has the right idea
Old May 14, 2001 | 11:51 AM
EVOCELICA's Avatar
New User
Default Re: All motor question (XtraFastCRX)
Yeah I would go with what EG6 says but be carefull when you use CTR pistons and a real thin head gasket you can't run a real insane cam like Toda or JUN because they have a very high lift and you have a very small amount of clearance.
Old May 15, 2001 | 11:25 PM
Default Re: All motor question (EVOCELICA)
he's talking about a thin head gasket if you go with itr pistons
Old May 16, 2001 | 11:38 AM
92Si's Avatar
New User
For that kind of power, you are also probably going to want a skunk2 ecu or similar program. Having the $$ and the parts is only 2/3 of the job, make sure you have someone who has put together a motor of this caliber before...
cp-jpn
Aug 16, 2006 01:37 PM
irunfromcops
Nov 3, 2002 06:28 PM
LethalX
Nov 21, 2001 06:52 PM
White Dragon
Aug 31, 2001 01:28 PM
Yellow Dragon
May 2, 2001 10:52 PM
