Please HELP!!! just did sirII swap
Re: Please HELP!!! just did sirII swap (b16cx)
Double check your connections and make sure that you have the right sensors hooked up to the corresponding plugs.
Hmm, I had a VTEC solenoid problem too, turned out the stupid wire had just come loose from the solenoid plug... just press extra-hard on all your connections (especially the one at the bottom of the VTEC solenoid, the wire actually comes loose from the terminal there, this is where my problem was) and see if that fixes it? HTH...
DraginTeg93
03-20-2007 11:50 AM
