Swapping pistons?
Old Apr 3, 2001 | 10:17 PM
hopelessrex's Avatar
New User
Default Swapping pistons?
Is it possible to swap b16a (pr3) pistons into a b18a? I see that the bores are the same but I am not sure of wristpin length. If it is possible what modifications need to be done in order for the pistons to work. Also if they will work what rings should I use to install them (b18a) or (b16a)? Any info will be appreciated.
Old Apr 4, 2001 | 06:46 AM
eg6ajk's Avatar
Default Re: Swapping pistons? (hopelessrex)
all b-series are interchangable (exclude b20b/z).....but at least most b16-b18 pistons are.....so yes it will work....wristpin comes only in the play when you use b16a rods with ITR/CTR/GSR pistons......as far as rings use b16a...
Old Apr 4, 2001 | 09:25 PM
New User
Default Re: Swapping pistons? (eg6ajk)
Ok well thats great. You don't have an idea of what kind of compression ratio I would have if I used these pistons along with a b16 head do you. I am guessing somewhere around 10 to 4 to 1 cause it would then pratically be a b16a itself. Well thanks for the info.
Old Apr 5, 2001 | 05:22 AM
eg6ajk's Avatar
the compression is in the 10.0-4:1 range which would be right depends on the gasket used.....
Old Apr 5, 2001 | 10:49 AM
New User
Thanks again you have been very helpful.
Old Jun 20, 2001 | 04:49 PM
adamp35's Avatar
New User
I beleive that the rods are a little wider on a b18a and must be milled on the sides to clear the piston. After they would have to be shot peened to give back the strength. As for copression... who knows?
Old Jun 20, 2001 | 06:56 PM
cjfinkle's Avatar
New User
Default Re: Swapping pistons? (adamp35)
I am not sure if you have to have the LS rods machined for PR3 pistons. I have heard that they are plug and play, but I am not positive. I am using P73 pistons and I had to have them machined about 1mm on each side. As far as compression ratios go, if you are going the ls/vtec route with the b16 head and b18a block, the pr3 pistons will give you a compression ratio of ~11.5:1. If this is your daily driver, you may want to consider p73 (ITR) pistons. The USDM ones will yield about 10.8:1 and the JDM about 11:1 with a b16 head and b18a block. I went the safer route and got USDM ITR pistons.
Old Jun 20, 2001 | 07:28 PM
1.8EG-T's Avatar
The rods need to be machined and the compression ratio is 11:5:1 with the b16a head and ls headgasket.
hbyrd8701
Mar 1, 2010 05:55 AM
ridestrt
Apr 24, 2003 11:22 AM
RSvtec
Oct 27, 2002 08:09 PM
moonski93@aol.com
Jul 18, 2002 07:29 PM
2latev8
Oct 27, 2001 11:29 PM
