R cams in GSR
New User
R cams in GSR
i'm a newbie sooo forgive me if this topic has been brought up before.
I have a rebuilt 94 B18c1 with GUDE regrinded cams, usdm r pistons, ported/matched intake mani, jun gears...
would i notice a big power difference going to r cams?? Is there an intake manifold issue as well?
TIA
TIA
Re: R cams in GSR (eg_hybrid)
regrinds cause wear on the components....depending on the setup it could be mild regrind or something wild....as far as best upgrade go wtih a Skunk2 manifold....more gain there.....
hard to answer becauase of unknown specs on the cams....they could match the ITR or CTR specs or produce less power....so its up to you..
i would defiantly do it if it was going from stock to ITR cams
If you are looking for some better cams to go with, I would suggest the Toda cams or some Jun cams. I can't comment on the cams you have now though.
James
James
JPerkMr954
04-05-2011 07:13 AM
PnX-R
01-15-2002 07:49 PM
