Hybrid exhaust ?
New User
Hybrid exhaust ?
Can i get by with my oem dx exhaust with my b18c swap? I know it'll majorly be choking things off but it won't be there long. Will it bolt up to the stock B18c manifold?
Re: Hybrid exhaust ? (eg6ajk)
What if he uses the B18C1 all the way to the Catalytic Converter ? Then go with say a Civic Si pipe from CAT back ?
That is depending on Hatchback Si though ....
Re: Hybrid exhaust ? (cheezemaster)
I hear the Del Sol B16A header will bolt right up. Not sure though.
I have an ITR/LS header and it reached the stock exhaust, but the bolts for the flange don't line up. I put on a Thermal anyway, so that worked for me!
New User
Re: Hybrid exhaust ? (Yellow Dragon)
Hmmm. Looks like i might have to bust out with the arch welder and rig something up temporarily. Anybody know a good place to find an oem itr exhaust?
Just leave the Headers through the CAT alone. Then you should be able to mount 3" extension from CAT to the B-Pipe, that's all (if using DX exhaust).
If you use a '92-'95 Si CAT back this mod is not needed.
Just get a Thermal exhaust like me. They sell a kit that would normally bolt up to Civic hb's '92-'95 with the stock exhaust manifold (with the cat ON the exhaust manifold). You can get a Thermal that has sort of a test pipe section for that missing gap. Works great for me. I have pics. I'll have to post them to show you. Or I can e-mail you.
New User
traded for greddy sp, off a 96-up hb, thing is i have a 95 hb. bolted right up after i welded on a 4 inch peice, took me five minutes.
anybody want to buy a cat?
HI91EFHB
07-04-2009 03:15 PM
Snail EK
02-26-2004 07:12 AM
