whats faster? b16a or b18b?
New User
Re: whats faster? b16a or b18b? (HondaCRX)
whats faster b16a or b18b? what has the most potential? which ones best for turbo?
<ul>[*]You can go LS/Vtec combo?[*]More displacement...can even stroke it out to a 2.0[*]Better for turbo...in my opinion if you plan on going all out!!!
New User
Re: whats faster? b16a or b18b? (dragonsmp)
Its in the air.
-I am Turbo'ing my B18a, which is fully built by the way. This motor will see upwards of 20psi. hopefully run mid 11's in a full interior civic ex.
-But I have seen a B16a take 12-14 lbs, and run with it on a stock bottom end. stock ecu, plain stock. Ran 12.1 @110?
-As far as all motor stock, the B16a should rightfully pull on a b18b.
The b16a has the vtec which helps out on the top end.
Re: whats faster? b16a or b18b? (WickedPerform)
New User
I have driven a 90 CRX drag car with a B16a stock bottom end at 14psi and it went 11.8 at 2600 feet elevation on slicks. That says something about the B16, I have never seen a B18b run that kind of power thru it!!
