B16A in a 90 civic
Old May 13, 2001 | 10:39 AM
HybridCivicVX's Avatar
New User
Default B16A in a 90 civic
I just bought a B16a and just wanted to know anything that I might need to get to swap this motor in a 90 civic. what harness, if I need motor mount kits or anything, or is it a direct bolt in, axles , any info is helpful...........thanks.
Old May 13, 2001 | 02:26 PM
eg6ajk's Avatar
Default Re: B16A in a 90 civic (HybridCivicVX)
need motor, b16a tranny y1, ys1, j1, s1, ecu pr3/pwo, reuse your old harness add vtec wires and knock sensor wires....(depends on the model)....halfshaft from 90-3 integra and axles will need to be used or any of the JDM halfshafts (other then y1).....mount kits will need to be used (hasport or hcp or place racing) shift linkage will need to be modified, as well as the throttle cable and clutch cable (or reused from 90-3 integra)....
check hybrid honda from more wiring and other things
Old May 13, 2001 | 09:06 PM
raene's Avatar
Damn man, you bought a motor without even knowing what you needed...? Are you rolling in the money or something?
DonnieDarko43786
Mar 3, 2008 03:44 PM
HTP26
Nov 5, 2007 01:06 PM
TMTNG9
Aug 2, 2005 07:46 PM
JONBLAZE55555
May 15, 2003 10:04 AM
brotherton16
Nov 24, 2002 08:48 PM
